1k reverse audio pot alternative
Started by powerplayj, January 25, 2020, 04:57:27 PM
powerplayj
Upon building the Woodstork, a 9mm, right angle PC mount pot with plastic shaft seems to be unobtainable.  The regular 1ck shaft pot is too thick  for a flush mount.  I would use a 1k audio taper and wire it backwards, to get fuzz on the ccw end of the rotation but smallbear doesn't have these (1ka)..  Aside from putting this in a larger inclosure and using non pcb mounted pots, what other options do I have?
Have any other values like a 2k or 5k?
You can change the taper of a linear pot to audio or revise audio by putting a resistor with 1/5 the resistance of your pot across pins 2 and 3 or 1 and 2, depending on your circuit.  You have to determine which leg of the pot on the hot side and then decide from there. Here's a link that explains in more detail.
http://www.geofex.com/Article_Folders/potsecrets/potscret.htm
powerplayj
#3
Quote from: jimilee on January 25, 2020, 05:25:59 PM
100k is the lowest reverse audio...5k, the lowest audio for this type pot
Quote from: powerplayj on January 26, 2020, 02:38:04 AM
A5k wires backwards will work, throw 5k resistor on it.
