Looking for a complex switching pedal builder in the Us
Started by Kremnuts, November 04, 2019, 12:11:34 AM
Kremnuts
I need a pedal to control two inputs and two outputs simultaneously in and Aby configuration with one output have a dedicated variable 0 to+6db boost...Any suggestions
Can you provide a little more detail? Where are the inputs coming from and where are the outputs going? When I think of aby, I'm thinking one input with two possible output paths.
Are you saying each input has two different outputs, and one output for each input has a dB boost?
