Acoustic guitar string question
Started by TNblueshawk, October 10, 2019, 01:31:01 PM
TNblueshawk
So I have a relatively new mahogany Martin and it is just a tad dark sounding for my tastes. When I plug in of course I can adjust and it sounds great. But unplugged I need more chime for what I like to hear.
Is there such a thing as some strings being more chimey than others? What strings might you guys suggest in this situation?
John
Congrats on the guitar! I've always wanted a Martin.
I don't have a specific recommendation other than to experiment and see what you like best, but in my experience strings can make a big difference in how an acoustic sounds. At least, that is, while the strings are still somewhat new, just as any other guitar strings as they age they'll sound more "dead".
I think D'Addario put a brightness chart on their electric strings, perhaps there is someone doing the same thing for acoustic strings.
The other thing to keep in mind is that acoustic guitars have a break in period. Once it's got a few weeks/months of playing, depending on how often it's played (and how it's played), it will start to sound different than when it's brand new. This may work in your favor.
Aleph Null
Different string compositions and even brands can definitely make a difference! I've had good results with 80/20 bronze on mahogany guitars (as opposed to phosphor bronze). John Pearse strings sound good on everything in my experience—if you can get them. You might also try Martin's own Marquis. They're pretty bright and probably easier to find.
P.S. Don't underestimate the contribution of the plectrum. Changing to a thicker pick might get you where you want to go.
TNblueshawk
Great suggestions guys. Thanks. I will poke around a bit.
John
Aentons
#4
You don't hear about them much but I like Gibson Brite Wires (acoustic and electric). They are very crisp and raw sounding. I have a SG electric and a rosewood SJ-200 acoustic and I use BW occasionally. They are the opposite of Elixirs. I use those sometimes too. I've had 2 sets of John Pearse strings for lower tension and broke the high e on both within 10 minutes
TNblueshawk
I ended up going with a company here in Nashville called Stringjoy and got some brass strings that really fit the bill. It did perk up me Martin. Now the question is how long will it last. If a good amount of time then I think I'll stick with them and I get to give back to a Nashville business.
John
vicfiveleven
Why don't you try a different type of pick? Material/shape/thickness.
TNblueshawk
Quote from: vicfiveleven on October 29, 2019, 02:01:51 PM
You know, I have tried so many picks over the years and I keep going back to a pick I'm comfortable with, ie. stays in my freaking fingers!. However, to your point I actually have a couple metal picks a friend got me. Generally I didn't like how those sounded on my Taylor or electrics but you just reminded me of them so I'll try on this guitar in particular to see what I think.
Anyone here like metal picks?
John
ahiddentableau
Not a big fan of metal, but I do like those newer-aged plastic picks (e.g. V-Picks, etc)  I think they're made of some kind of acrylic.  Especially if you're a pickdropper, the combination of more thickness and the tackiness of the plastic might be something you'd like.  I have a couple and I'm pretty fond of one design in particular.  It has a more serverely bevelled edge that makes it easier to get a bright, clear attack.
Timko
I generally opt for DAdderio Nickel Bronze on my 2 acoustics (a vintage Yamaha and a vintage Guild).  The Yamaha is the more Martin sounding of the two (the Guild has a more balanced, slightly brighter than a J-45 sound), and they do remarkably well on that guitar.  It sounds like some older vintage Martins I've played; big booming low end, mid scoop, and a bell like top end.  The suggestions of a different material/thickness for a pick are also good.
A mahogany guitar (I've been pining over a Guild M-20 for years now) is going to have a more mellow sound; the lack of a spruce top is the biggest factor in that.  String companies make brighter strings, but if the mellow sound isn't what you're after, you may be better off with a spruce top on a 18 (mahogany back  & sides) or a 28 (rosewood back & sides) guitar.
