Man O War Deluxe
Started by danfrank, September 29, 2019, 01:17:25 AM
Quote from: Cybercow on November 05, 2019, 04:14:33 AM
Quote from: madbean on November 02, 2019, 01:04:38 AM
I'm working on the LED bug issue right now and it's actually a bit tougher nut to crack than I initially thought (as far as finding the simplest, least intrusive fix). I think I know what to do at this point. I should have a final update tomorrow.
Any further word on this? I'm about done populating my Man-O-War Deluxe and currently on hold to leave room for any mods if need be. Thanks!
Solution has been found! Or rather, you found it :) A 2M2 from IC pin3 to ground fixes the issue. I'll type up the correction and post it in the errata section.
Mark, expect a little something in the mail from me soon. This one had be knackered. I tried several other solutions before yours and none of them were nearly as easy or clever. You kinda saved my bacon here.
Cybercow
Quote from: madbean on November 06, 2019, 12:51:14 AM
Brian - that's rather re-assuring. Thanks! Now I feel better both about what I recall about electronics and moving forward with this build. Here's how I plan to tack a 1/8 watt 2M2 Ω resistor from the center pin of the 3-way toggle (which is connected directly to pin 3 of IC 7-A) to ground - at the #1 lug of the Feedback pot nearby. (hopefully the image uploaded correctly.)
Glad I could help.
Cybercow - aka: Mark Davis
"Don't let your talent take you where your character can't keep you."
