I just fail
Started by yanko_mr, November 07, 2011, 05:11:36 PM
yanko_mr
Hello, well I start my first project and I just fail, jaja I tried the Mudbunny project, but with a peer hole PCB, it was going well (I put all the resistors, caps and stuff) but the wiring is jut to hard, so i think about order the PCB, and use the material I already have (but its all solder to the PCB and cut), Meh, I just fail. I also need 3 more caps since I order superficial mount ones... Arrrrggg, and my closest electronic store is 2 hours away...
Where are you and what caps do you need? Chances are that someone can help you out. I can help you if you're in Canada...
bigmufffuzzwizz
Yea it's hard at first but gets easier as you figure out methods and ways to make it work for you. What part values are you missing? There's a site you can get all of it (a few caps most definitely) for less than a dollar and shipping will be $1. Save your gas and time  :)
