PCB design in eagle for a PCB mounted on 1590bb enclosure
Started by darthandre, July 29, 2019, 12:00:14 AM
darthandre
Hello there! I'm currently working on a pedal and i'm trying to design the PCB to mount it on the enclosure but I need to import my enclosure design in eagle, thats the solution for a while to fit potentiometers and stuff like that with the enclosure.
Any recomendation to fit pots and switches with my enclosure design ? As i have mentioned, i'm using eagle ???
DLW
Do you already have the enclosure drilled? If so, it'd be easiest to measure the holes on the enclosure and lay out the board accordingly. If not, design the PCB and "print PDF" of the board; it is 100% scale.
