Transistor equivalent/substitutes
Started by Bio77, June 26, 2019, 08:25:27 PM
I'm looking for subs for 2sc2603 and 2sc732 transistors.  I did the usual, search google/forums for data sheets and posts about transistors that people have used.  Is there a better way?  Excluding phasers, are there particular parameters that are most important for buffer and amplifier circuits?
Well, for Si NPN being used as an amplifier/buffer, I've only ever cared about hFE
I use el-component.com for a rough idea, but they don't seem to have either of your transistors in their database.
Hirezach
Bio77 , did you ever figure out good substitutions for these two? I've been researching these all night and aren't sure what to use.
If you are building the Backfeeder.  I never got mine to work without noise.  I actually built two, same problem both times.  Cooder has a working one.  You can see his recommendations here:
https://www.madbeanpedals.com/forum/index.php?topic=30479.msg294159#msg294159
Hirezach
Uh, oh... yeah, it's the Backfeeder! How bad's the noise on yours?
I'll check that link now. Thanks!
