road rage 12v output
Started by fritz, May 24, 2019, 11:00:57 AM
fritz
hi there
is there a simple way to modify my road rage to output 12v? (used a lt1054)
road rage: ttp://www.madbeanpedals.com/projects/_folders/Other/pdf/RoadRage_2015.pdf
found this, but do not understand it.
"....2. If you're using a regulated power supply -- or even just a One-Spot or anything else that puts out a consistent voltage -- use a few diodes to knock the input voltage down to about 7V. A single green LED might even do it. You can't really use a 6V regulator with a heat sink because your final voltage would be closer to 11V than 12V."
http://www.madbeanpedals.com/forum/index.php?topic=16281.msg154171#msg154171
thanks
Follow the instructions for building it for 15V but use a 12V regulator for REG1.
fritz
