Does this only happen to me???
Started by Caedarn, May 11, 2019, 11:17:45 PM
Caedarn
Okay, so I'm pretty new to pedal building.  A few months ago, I planned out about a dozen projects and made my first round of part purchases from Mouser, Small Bear, etc. etc.  Got through a half dozen builds or so, no problems.  Then I started a build of a Tube Screamer type project, and found that I had neglected to order 510k resistors.  Yes, I know I could combine resistors, but wanted the build to be clean, so figured I'd put it aside and come back to it down the road.  I started another build at random, and sure enough that one also needed 510k resistors. So I took it as a sign from on high, and figured I'd order them.  But I'm not going to order just 510k resistors,  because if I'm going to pay the grand sum of $7 for shipping, I'm going to make it count, right? So I embark on planning out the next phase of pedal builds, and all the additional parts I'll need, which then turns in to ordering a bunch of stuff not only from Mouser, but Small Bear, Tayda, and so on.
So I'm going through my Mouser shipment, eager to get back to my Tube Screamer, and guess what I forgot to include on the order.....Yes, you guessed right - 510k resistors.
I've done a lot of carpentry, and as the old saying goes: measure twice, cut once.  Pedal building is similar.  But now I've got to remember to apply the same rule to ordering stuff.  Check your work  ::)
This kinda feels like most parts orders I do, too. I always forget something and quite often the thing that started it all. But, I sure as hell seem to order a lot of stuff that never gets used. The problem with browsing Mouser is I always find something where I think "oh yeah, I'll figure out a way to use that in something". Yeah...not so much.
Log in, add it to yours and leave it. When you go to order things, it will be there.
Arrow.com
Free shipping, no minimum order. The search function blows (triple check to make sure you're getting the right sized resistors) and they deforsest small nations to package single orders, but its great for those "ah hell, I forgot" moments
Quote from: jimilee on May 12, 2019, 12:03:47 AM
This works for some places but I have to say it doesnt work for Smallbear. I have lost quite a few carts because it seems to reset after a while. I always take a screen shot of my temp cart at Smallbear now.
Back to the OT, this happens to me all the time. I guess the way I deal with it is to have so many projects in backlog, that I just move onto something else. I think it's really the only way to do this hobby. You have to really build up a huge collection of components and projects or be extra careful when ordering parts for each project.
Caedarn
#5
Actually, I did that initially with a few parts, but then removed them.   I have a giant spreadsheet with all my projects in it and I create Mouser BoMs from it.  When I decided to order the necessary parts for a dozen more projects, I started the cart over again with my spreadsheet BoM, so I wasn't double ordering....
Earlier today I made a Mouser project called "Stuff I Forgot"
Caedarn
Quote from: peAk on May 12, 2019, 12:19:06 AM
Yes, I learned this about the Small Bear shopping cart the hard way as well....
Caedarn
Quote from: somnif on May 12, 2019, 12:11:30 AM
Arrow.com
Thanks for the tip.  I might try them. Then again, once the build docs for the Harbinger 1.5 and Polytrog are posted, I'm probably going to want to add those to the queue and buy parts for those, so I might just hold off for now and go on to the next project.
TFZ
I always have a shitload of different projects going on at the same time, not just pedals, in various stages from development to actual building. Since most of these don't have to be finished at any certain time, they can be lying around for months or years and progress at different speeds. Unless I want to finish a particular thing and I stumble upon parts I am missing, I note them down in a spreadsheet. The parts are sorted by supplier (with annotation for what project, or I wouldn't remember what half the stuff was for), so once I order from Mouser when something more pressing comes up, I won't forget anything I want from Mouser.
Since you are new to effects building/electronics, you have to build up some stock of standard parts. Definitely get a full set of resistors from 1R to 10M, also a range of typical capacitors, ICs and transistors. There are several threads here where reasonable things to buy for beginners are discussed.
Never fails. Always, and I mean, always happens to me.
fair.child
You know that 470k might work for substituting 510k. Plus, there's always Amazon/Arrow/eBay if you need get 510k.
Berger
Yup, same as above. I've also got in the habit of ordering something I 'think' I don't have only to find that I already have multiple... ::)
Parts Jar section of the forum has saved me a couple of times.  BTW, I've got some 510ks I can drop in the mail for you.  Just PM me.
Quote from: Bio77 on May 12, 2019, 05:18:46 AM
Yes, Parts Jar is just the ticket for this type of d'oh:
http://www.madbeanpedals.com/forum/index.php?board=22.0
I'd build carts over a period of months and when placing time came i'd go over it and there'd often be parts i had no idea why they were there so i'd delete. Unpacking the order seemed to always jar to memory what they were for and why i'd be adding them back into the next cart.
