VFE Choral Reef Control Settings for Small Clone Sound
Started by Bio77, March 30, 2019, 10:45:53 PM
What settings on all the extra Choral Reef controls gets you closest to a Small Clone?
Aentons
I think the Width knob is prob the only real wildcard. I'm not sure but it prob uses the standard chorus settings with Mix at 50% and Feedback off. I imagine the Range knob is set to medium which is to the right and Depth at noon.
Aentons
Ok, so I got curious and looked to see if there was any info about what the delay time may be for the Small Clone and the only info I found figured it was centered around 15-16 ms.
And so I looked up the specs for the chip delay times.
MN3007 = 5-51 ms
MN3008 = 10-102 ms
I'm not sure how the ranges are divided on the Choral Reef but it seems that 15 ms may be on shorter range, which is the middle position.
Thanks for the input.
I got it sounding good with your suggestions (Range switch to the right, Feedback and Width set to 0 and the Mix at~1:00). I A/B-ed it with my Small Clone and I'm a convert, sounds really nice.
