Epic Looper WIP: 6/21 update - FINISHED!
Started by Leevibe, March 23, 2019, 11:10:22 PM
Here are the final 2 images of the WIP. I finished it up last week and everything works! These show more 3D printed parts. In order to implement the 7 segment display I needed a solid way to mount it. I couldn't have it board mounted because of the way I had the switch and hole configured. It required me to solder tack flying leads to all of the pins but it wasn't too hard and it works perfectly.
I will have a build report up soon with pics of the finished build and a video showing how it works.
Regular Sean
thecadman2017
Hello I am new here and my name is Manny.
I need help wiring the switch daughter boards....I have checked the traces but they  seem to
not be continuous. I like the way you hooked up the two leds with the same ground leg. Nifty :))
I have drawn a copy of the daughter board and would like it if you could trace thru it...is it wrong ??
Thank you and your looper is looking very good.
Manny
