Connection plugs for PCB holes
Started by Marshall Arts, March 19, 2019, 01:19:12 PM
Marshall Arts
Someone here posted an image about some sort of plug that fits into the holes for through-hole-components, which would be perfect for evaluating component values without having to put solder in the holes. I just dont find it any more... any help is welcome!
You mean sockets?
They were spring-loaded test-pin-like things, as I recall.  I remember the post, but can't remember the product either.
I think they popped into the holes of a PCB, gripping the sides and allowing a temporary electrical connection without soldering, right?
Marshall Arts
Quote from: EBK on March 19, 2019, 03:12:55 PM
Right.
Quote from: EBK on March 19, 2019, 03:49:12 PM
https://www.adafruit.com/product/3823?gclid=Cj0KCQjwpsLkBRDpARIsAKoYI8yhUQGqo7ElmlHqhxvIJGfFaFmQhvYfmAxErlOQQ5tMyHnAk4GBw80aAmM7EALw_wcB
For completeness,
http://www.madbeanpedals.com/forum/index.php?topic=28543.msg276921#msg276921
Glad I saw this. I needs to get me some of those. I've tried different things but I usually end up clipping to other leads in circuit. It would be super handy to pop those suckers in and clip to them.
trailer
#7
I have about 100 of these and can toss some in envelopes for folks wanting to give them a try. I still haven't tried them but they are tiny!
Shoot me a PM.
Marshall Arts
Quote from: trailer on March 19, 2019, 04:54:40 PM
I about 100 of these and toss some in envelopes for folks wanting to give them a try. I still haven't tried them but they are tiny!
Shoot me a PM.
Just bought 100 myself... Guess I'm covered, but thanks!
I have some of these and I find they really are better when soldered in.  I find them frustrating when trying to use them as a snap connector.  I far prefer Pomona minigrabbers.
Quote from: pickdropper on March 19, 2019, 05:14:36 PM
I usually use mini grabbers. They work pretty well. It just takes that extra work to trace the layout to find what to clip to. And I use the cheap ones, so they aren't always good at staying connected. I'll have to look at Pomona. Are they spendy?
Quote from: Leevibe on March 19, 2019, 05:44:27 PM
Pomona stuff is generally spending, but they last a while and you probably don't need a ton of them.  They are a lot cheaper if you just buy the clips and wire them up yourself.  I think they are few dollars a piece when purchased that way from Mouser.  It's been a while, though.
Quote from: pickdropper on March 19, 2019, 05:52:02 PM
Thanks. I'll give them a look.
Being the cheap bastard that I am, I usually just trace the net that the pcb hole is on, and tack a flying wire onto an already soldered hole.
I have a solid idea on how to DIY these and be even better...or so I think. Experimentation to follow!
