transistors for weener build
Started by movinginslomo, November 08, 2018, 10:43:03 PM
movinginslomo
decide to populate the weener board in the stock clyde form for future use with the whipple inductor. The BOM cals for bc108's. Are gains of the actual transistors all that important in this build? I have the 70's crybaby board with whatever transistors are on it, could I re-use those? I found the sound of the 70's TDK craybaby to be somewhat lame, hence the start of this entire wah mission. Would the old transistors be a possible cause of why the crybaby sounded so lackluster? The geofx "technology of the wah" article suggests the transistors aren't a major factor in the sound
movinginslomo
TFZ
Take anything with highish gain, 300-400 or more, and it should work fine. A BC550C is cents, I doubt that 50 year old silicon is lower noise or "sounds better". BC108/9 is basically the same thing, just the older version.
movinginslomo
Quote from: TFZ on November 12, 2018, 08:28:25 PM
so any bc108/109 from smallbear in the 300-400-ish range should be suitable?
TFZ
