loris question
Started by lloyd17, October 08, 2011, 07:09:40 PM
lloyd17
So I am building the Slow Loris and I didn't order up any 30pf caps. Can I sub in a 50pf or would it be better to tie two 50pf in series for a closer match to the original value?
I think in the purpose it's being used for, up to about 100pF won't produce a discernible difference. After that it may not be detectable either.
lloyd17
Thanks guys, I'll likely pull the 50pf and toss in some sockets.
Shoot - I thought he meant C4... yes, C4 can be anything up to about 100pF without causing any difference in sound. The 30pF is a different sort of thing. Socketing is a great idea.
jacob
lloyd17
Thanks again guys, your tips were dead on. I pulled the 50pf I had in there and installed some sockets. Since I am too lazy to head out to the electroshop for a couple ceramics I played around with series/parallel values and settles on 3 47pf in series for around 16pf total and wow, what a difference. The sweet spot on the cut control is now around 11 o'clock rather than 8 and the ruetz never gets muddy. Perfect!  I could see making a switching mod out of this: brighter for humbuckers and darker for single coils.
jimmybjj
glad it worked out for you. I was surprise how much of a difference that cap made.
Pcbs no longer available
