Always On (Eliminating footswitch) Tonal Recall
Started by Earz4Beerz, July 17, 2018, 11:39:13 PM
Earz4Beerz
Hi Folks,
Switches am I right?
They always confuse me.
Making a Tonal Recall right now for someone who uses it as an always on effect.
Im eliminating the switch in an effort to save a little space.
What I don't understand is on the PCB S1 what the the second negative pad?
Can I just jump S1 positive to S2 positive and S1 negative to S2 negative... but what the heck do I do with the second S1 negative?
Am I opening a can of worms here?
Thanks in advance
Earz4Beerz
Not really sure what you mean by "negative" and "positive" pads, but if you want to eliminate the switch simply jumper S1_1 and S1_2 together. You can also omit R61, LED and S2!
