Fusie
Started by cooder, May 26, 2018, 07:51:58 AM
Fusie.... means apparently "Merger" in Dutch. Made this for a friend who plays mainly acoustic stuff.
He wanted a pedal where he can blend two acoustic pickups (one under saddle  piezo and one magnetic soundhole pickup) together via separate pre amps (rullywow 'chuggapre' aka TC electronics pre amp) with treble bass into a mixer to blend into mono signal.
Inputs can be just one mono cable run into input A (if he doesn't want to use two pickups) in this case input B is grounded via jack A. In that case only preamp A is active obviously.
Input A can also take a stereo cable if both pick up signals come through stereo cable. Both preamps are active and can be blended.
Or two mono inputs, obviously both preamps active.
After that option of effectsloop to splice in other effects.
At the end a buffer/splitter to send signal to two seperate amps/PA or so, the outputs are footswitchable for both on / A or B on only.
Works all peachy, he's happy.
Sharp! I can see a couple guys being interested in this :)
My supervisor at work bought a looper pedal off me, just to switch between his acoustic guitar, and his electric, going into his amp.
blearyeyes
Good one cooder. Impressed.
Boba7
Yez, super useful I think, and it looks perfect too. Very inspiring, makes me wanna build something for my acoustic rig!! :)
Great job!
