How the JCM800 Circuit Works
Started by culturejam, April 05, 2018, 12:57:24 AM
This is a great technical analysis of the JCM800:
https://robrobinette.com/How_the_Marshall_JCM800_Works.htm
Just thought I'd share. It's probably already been posted here, but I don't recall seeing it.
Quote from: culturejam on April 05, 2018, 12:57:24 AM
His site is great in general.  He breaks a lot of stuff down very well.
mjcyates
I built my first 2 amps (5f1, 5e3) using his layouts and they both turned out great!
ahiddentableau
Rob's site is the best.
Has anyone built any of his micro amps?  He has cool low power layouts of classic circuits (5E3, 5F6a, 5F1 are all there if memory serves) built around low power transformers (Hammond 270BX-ish power and fender reverb transformers used as a low power push-pull output) and tubes (12AU7 or 12BH7 dual triodes used in a single tube push-pull configuration).  I've always wanted to build one, but would like to hear some feedback beyond what's on the site.
Manc
Pretty good info, I was aware of this page and I keep going back to it as reference.
After a few direct clone builds I have started toying with the idea of putting together a high gain 18w JCM800 amp. Probably powered by a couple 6v6, with a SS rectifier.
I am also trying to figure out a switchable boost, to get a faux dual channel.
Robs pages are a mine of ideas!
Quote from: Manc on April 09, 2018, 05:50:37 PM
What I really want to do is a single-ended version of this Phaez Daisycutter circuit (which sounds very Marshally):
Or the attached, which is similar but with a single tone control.
I know there are some of those out there that Phaez built, but I think it would be a fun project.
Manc
That is neat!
I also found a 18w power transformer (from Ampmaker) that has three secondary windings. You can connect a three way rotary to get 100%, 50% and 1/10th of B+!
http://www.ampmaker.com/store/0-190-275V-20W-power-transformer.html
Quote from: Manc on April 11, 2018, 10:28:24 AM
That is neat!
That is awesome!
Manc
What's really good is that the heathers winding will always put out 6.3v
Sort of a Variac, but only where it's needed.
Quote from: Manc on April 11, 2018, 03:17:52 PM
Late 80s flashback  ;D
