Choral Reef / v2.1 Switching Board Fail - SOLVED!!!
Started by brucer, February 07, 2018, 07:53:41 AM
brucer
I'm pretty sure the fail will be down to me, but ... I've built up a Choral Reef and v2.1 switching board.  I get bypass signal, but utter silence when switched to effect.  No parts substitutions, just what was in the BOMs from Mouser and Small Bear.
I have power to the switching board, but seeing no power at the Choral Reef.  I've confirmed continuity between the switching board and the effect pcb, so guessing that means the the switching board is the (first) problem.  I've checked my solder joints and parts orientations.
Wondering about next steps.  Can't figure out how to use my testing rig with the VFE projects since everything is basically complete, signal through jacks, etc.  Only thing that comes to mind is checking voltages on the switching board parts.
Does anyone have a list of voltages for the v2.1 switching board that they could post as a comparison?  Or any other suggestions how to troubleshoot on of these projects?
Thanks for any/all ideas.
bsoncini
#1
Do you hear the relay click when you press the momentary switch?  What voltages do you have going to the actual board.  Should be around 9 volts on v+ and around 5 on v-.  If all that is good.  Post your voltages at all ic's
Edit
Looking closer.  It looks like you need to flip the switching board over and flip the wires too.  Your Led, in, out are connected to gnd v- and v+. And vice versa.
Good catch!  It's like an optical illusion.
brucer
Quote from: bsoncini on February 07, 2018, 08:11:01 AM
D'oh!  That would totally explain things.  Flipped the switching board/wires over and voila!  Fired right up.  I am such a toad.  Thanks for helping though!  Much appreciated!
bsoncini
Glad you got it working. We've all made stupid mistakes like that
Droogie
Droogie
Quote from: bsoncini on February 08, 2018, 07:38:11 AM
I seem to do that at least once on every VFE build I've done, except for the last two Mermans.
tcpoint
Nice build.  I like that Choral Reef, a lot.  I fired up a pedal, a couple days ago, bypass worked perfectly and no sound.  I looked at the board and forgot to put in the opamps.  Then, it worked, next try.
