3P2-4T vs. 3P4T
Started by GeorgeFormanGrill, January 27, 2018, 05:53:49 PM
GeorgeFormanGrill
Hi all:
I'm trying to create this clone of a Lovetone Big Cheese, and the schematic calls for a 3P4T rotary switch. This is my first time working on a project with that kind of switch, so would love a little guidance.
http://www.geofex.com/Article_Folders/grtchedrschm6.PDF
Looking to buy this switch from Mammoth Electronics – would a 3P2-4T switch do the trick? What's the difference between this and a 3P4T version?
https://www.mammothelectronics.com/collections/rotary-switches/products/alpha-2-4-position-rotary-switch-pc-mount
Thanks in advance.
George
Rotary switches have a ring that can be repositioned to change the number of throws.  The switch you're looking at can have either 2, 3 or 4 throws, so it will work for your project.
bsoncini
That should work fine. With those switches there is a little washer that you set if you want it to turn 2,3 or 4 times.
If they have ones with solder lugs they will be easier to solder but still easy enough with the PCB mount.
GeorgeFormanGrill
Awesome. Thanks for the quick reply!
