Sharkfin 2015 - some parts on board not on build doc
Started by Bret608, November 15, 2017, 09:04:17 PM
Hi everyone--so, I have a Sharkfin board that someone kindly PIF'ed me a while back that I am finally getting around to planning to build. I notice there are a few parts on the board silkscreen that are not on the build doc, either the board image or the B.O.M. They are Q1, C17, R35, and R36 along with an LED 2. I feel like I remember that all being for a rate indicator on the filter side that Brian ended up removing later because it didn't work as expected. Is that the case, and am I safe just leaving those off?
Thanks!
BrianS
I have the same board and if it's not on the build doc then leave it off.
Simple explanation - you don't have a Sharkfin 2015 board. You have a prototype board I must have given away to someone a long time ago. I'd need a picture of the top of the PCB to identify it exactly.
