TimRay
Started by pickdropper, November 06, 2017, 12:40:50 PM
A while back, a friend of mine asked if I would do a mini Jan Ray Vemuram.  Since I had already done a Timmy layout, I agreed to modify it and get a few boards made.  I finally got around to making artwork for it and building one up.  I really like the way the build looks, I'm still not sure I'm sold on the circuit yet.  So far, I prefer the Timmy, but I haven't played enough with this yet.
FWIW, this is my etching fixture for laser engraving.  The box screws to the fixture to hold it in a defined place.
brejna
Awesome build as always. Do you have spare pcbs, I would like to buy one if possible..
Cheers
Brane
Quote from: brejna on November 06, 2017, 12:57:38 PM
Cheers
Brane
I have two or three.  I didn't buy many.  If you want one, shoot me a PM
storyboardist
As always, that's a great looking build. Nice work with the engraver template too.
Guy behind Effects Layouts
MAN that thing looks perfect!
BrianS
Adam_DIY
Insane levels of perfection as usual.
trotel
Looks beautiful!  I like how the rays bend over the top.
Love the simplicity of the artwork. still optically very effective.
287m
Amazing build as always
here the question came :D
are you always use flying wire the pots? and not stranded?
Quote from: 287m on November 06, 2017, 06:37:56 PM
It is stranded wire.  I use 3-conductor stranded ribbon wire to go from the board to the pots.  It's Amphenol Spectra-Flex.  I used 4-conductor Spectra-Flex to go from the PCB to the 3PDT switch board.  The rest of the wire is Small Bear pre-bond wire.  That stuff is great to work with.
Martan
Looks awesome! I love the depth around the laser work. Nice work on the jig for holding the pedal. Is there a defined spot for aiming the laser at or is it just the top right corner?
Quote from: Martan on November 07, 2017, 03:45:24 PM
The laser itself always references to the upper left corner.  The problem with that is that there is a little bit of variability in the enclosures themselves, especially after powder coat.
The advantage of the fixture is that it puts the screws in a defined location so I can use the center of the enclosure as the focal point.  This theoretically will help center the artwork even if there is a bit of dimensional variation.
There is still the issue of the laser calibration itself changing over time.  The best way is to do a full recalibration of the bed regularly, but that's very time consuming and easy to get wrong.  Instead, I offset the fixture with a 1x1 spacer.  Periodically, I recut a new spacer.  Even if it's not truly at the 1x1 reference point, the software thinks it is so it still works.
soldersqueeze
Your pedals are cleaner, prettier and better made than any production pedal i've ever owned. This is no exception. Wonderful work.
