FireBomb Help!!!!
Started by giospa, September 09, 2011, 11:35:44 AM
giospa
I i'm new in this forum ;) ....  i do 2 project from this site... the g-2 and the firebomb dual booster.....
now.... in the firebomb pcb there are R1 and R10.... but on the component list there aren't :( .....
i put two jumper for r1 and r 10... but the effect doesn't work !!!!! like the g-2 that doesn't work :(
can anyone help me?!?!?!?
sorry for my english.... i'm a young italian boy xD
mgwhit
R1 and R10 only appear to be on the etched version, not the manufactured board, so I'm going to assume you etched your own.  Both resistors appear to be pull down resistors at the inbut of each half of the dual circuit.  In a typical pedal you would expect to see a value of about 1M there, but I don't think they are required in this particular build.  You may safely omit them.  By jumpering them, you are sending 100% of your signal to ground the second it hits the board, hence no sound.
Good luck!
dwstanford
Yeah, just remove the jumpers and you should have it.
giospa
thanks a lot :D
tomorrow i try to do that ;)
