CJOD
Started by pickdropper, September 15, 2017, 03:56:18 PM
I've built a number of Tube Screamers over the years with various mods, but I can't remember if I ever made the exact Clay Jones overdrive version, so I decided to give it a go.  Contrary to my normal modus operandi, I went with almost zero extra features.  My only indulgence was an internal header to change the clipping from LED to Si diodes should I choose.  It's actually a great sounding Tube Screamer variant.  I see why people dig it.
This is another Tayda enclosure.  It's not perfect but it's significantly better than the black ones.  For whatever reason, their black and white enclosures are really rough and the other colors have been decent, if not spectacular.
I need to clean up the backfill a bit on the etch at some point.
Ralfg
That looks awesome! You make me want to get a laser machine to do some etching. These your own PCBs? Where are you getting them made? The layout is really nice and the build is super clean. #pedalgoals  ;D
Cool layout, the jumper idea is a great one, and well placed by the diodes too.
storyboardist
So clean! How is the board mounted? The pots or taped to the box jacks?
Guy behind Effects Layouts
Andlord
Do you also build other formats than 1590A? Those are superb, how the hell to you squeeze them in there???
Quote from: Ralfg on September 15, 2017, 04:09:18 PM
Thanks man.  Yeah, the PCB was my own layout.  I ordered this particular board from Elecrow.
Quote from: storyboardist on September 15, 2017, 06:51:19 PM
I always use full size enclosed jacks and mount the boards with industrial grade 3M VHB tape.  There's really nowhere for the board to go, so it doesn't have to be mounted at all, but I like things to be fixed in place and neat, so I always do it that way.
Quote from: Andlord on September 15, 2017, 07:53:38 PM
The majority of my building these days is in larger boxes, but I always enjoy the fun of 1590a builds.  When I build for myself, that's what I mostly do, but it varies.
Coda-effects
Super clean build as always!
Love the telefunken logo :)
Is that acrylic in the etch fill?
Also, I love the header switch idea. I've done that on a few boards, but never the 90-degree setup that one has. Very cool.
Quote from: culturejam on September 18, 2017, 02:18:12 AM
Yep, that's acrylic in the etch fill.  I didn't end up wiping this one off with alcohol, though.  I applied the fill with a syringe under a microscope, so I got it very close to correct without wiping.  There are a couple of areas I need to touch up, though.
