Mini ToneBender MkI
Started by pickdropper, August 22, 2017, 07:57:47 PM
Just finished this for a gentleman on TGP.  It's a TB MkI with a voltage inverter circuit in a 1590a. He wanted it a more traditional build with simple graphics similar to the original. I couldn't fit Tone Bender in a single like like the original, so I staggered the Tone and Bender. I used a Pewter Vein enclosure for the first time, which has a cool textured look, but has basically zero contrast when laser etched (the text is basically invisible). So I had to back fill with black acrylic paint and then clean it up with alcohol.
I actually did two boards, one with adjustable bias and one with fixed bias. I built both to verify. Soooo, since I had an extra populated board, I threw it in a Bowie-esque silver sparkle enclosure I had kicking around. I went with period-incorrect graphics similar to the Tonebender MkII, because that's what I wanted to do. ;-)
Impeccable. Great layout and definitely prefer the clean lines on 'yours.'
I've been thinking it'd be fun to do a layout like that with SMD IC and power supply parts on the backside so just the MOJOs are visible.
Classic pickdropper, so. Lean and neat. First one looks like a tombstone.
Quote from: jubal81 on August 22, 2017, 08:05:04 PM
Or you could confuse people and put the Mojo on the underside and the SMD parts on top. ;-)
Quote from: jimilee on August 22, 2017, 08:26:26 PM
You know, it does sort of look like a tombstone.  I hadn't thought of that.
storyboardist
Holy crap that's clean. What a layout! Well done.
Guy behind Effects Layouts
Wow! This is actually the first time I remember seeing a MkI on a fabbed PCB at all, much less in a 1590a. I'm sure the bias trimmers help as this circuit is very picky about transistors. If you have a big enough stash of germaniums with a range of gains and leakeages, it's not as hard to build as people say. Anyway, I like the look of both these builds quite a lot.
Cool builds!  I like the pewter wrinkle finish. Kind of a throwback look but with a modern 1590a sans serif spin.
Have to laugh at this thread because I just yesterday finished an npn smd tonebender layout. I also did one variant with smd and npn germs. No mojo and submojo.
But also smiling because of the lone smd resistor on the switch pcb.
Adam_DIY
Wow they look amazing simply wow.
cajone5
Awesome work. So clean. Wish I could build in those tiny enclosures and maintain my sanity
Out of curiosity... what does one of those go for?
Quote from: Govmnt_Lacky on August 24, 2017, 12:56:04 PM
Kan I Haz PCB two?  <('o'<)
Quote from: flanagan0718 on August 24, 2017, 01:22:37 PM
LOL.... actually I was referring to a full build. How much for a completed build?
I quoted $180, but ended up cutting it down to $170 as an apology for how long to finish it.
I am actually going to post my semi-annual list of PCBs that I have for sale.  These will be included in that.
