Traces fell off. Workaround?
Started by EndlessOcean, September 03, 2011, 01:24:04 AM
EndlessOcean
Went to change a Q, the trace came off when I was desoldering the middle leg of the transistor, effectively cutting the circuit.
Any ideas how I can get around it?
I'm wondering about getting a bare wire from the trace before the Q to after the Q and then soldering the tranny legs to the wire, but not sure if this would work.
shawnee
Mike @ Rawkworks
That'll work. Or use the trim from a resistor, those are usually pretty small
Mike
mike@rawkworks.com
