XLR to line level question
Started by zilla, August 10, 2017, 10:27:16 PM
zilla
hi all,
i'm not that familiy with XLRs and balanced signals so this might be a really basic question.
I'm trying to make a simple 3-channel mixer that can take XLR balanced and 1/4" unbalanced signals, mix them, and then output a balanced XLR signal .
The output side is no problem - i found an active DI circuit that i can use to convert the mixer output to a balanced signal.
The problem is on the input side.  I'm not sure how to get the XLR signal into the AMZ mixer circuit "properly".  Do i just take the ground and pin 3 of the XLR and use those or is there something else that i need to do to the signal first before it goes into the mixer?
Thanks
T
