The Wave
Started by pickdropper, July 23, 2017, 09:53:23 PM
Tuxedo3
Totally beautiful. Awesome build.
Very cool!  fantastic etch, didn't realize how much I missed access to a laser until just now.
Quote from: EBK on July 24, 2017, 02:55:24 PM
For the acrylic, would the switches and knobs be mounted only to the underlying enclosure and not physically touching the acrylic (due to carefully oversized holes)?  Wondering about cracking....
The hardware mounts to aluminum enclosure from the bottom and the acrylic plate from the top.  You'd have to really over tighten to crack the acrylic.
Wow!  Most impressive build, congrats Dave  :)
Philthy
We haven't seen a build from you in a while...glad to see you're still SLAYING IT!!!
Wow!
Not much I can say that hasn't already been said.
Beautiful
Boba7
Fantastic, amazing, beautiful, great great job!!
Coda-effects
Wow, just wow!
Amazing as usual.
Thanks for the kind words.  I really appreciate it.
Anyone else totally in awe of the tiny bits of heat shrink managing the wire runs?  Silly attention to detail.
Quote from: gordo on July 28, 2017, 01:20:51 AM
Yes!  At first glance, I even thought the gut pic was pre-wiring.  Very neat and tidy.
PhiloB
Amazing all around.  That reverse etch really caught my eye!  Where Doug you buy your pieces of acrylic and do you recommend a particular thickness?
Quote from: PhiloB on July 29, 2017, 04:33:11 AM
I usually get them from either McMaster Carr or Delvie's Plastics.  You'll want to use 1/16" thick acrylic.  Anything thicker than that and you won't be able to screw down the nut on the potentiometers.  Even with 1/16", you can't use 9mm pots, but 16mm pots will work fine.
