Expandora / Muff
Started by DGWVI, May 29, 2017, 10:56:12 PM
DGWVI
JMK Expandora into a Rullywow Muff Opportunity in a 1590D. Wiring's not the tidiest, most of the leads could probably be cut down to half. Still deciding whether I want to label and apply graphics
I decided I didnt care for either the crunch or overdrive modes on the Expandora, so I made only the distortion and forbidden settings footswitchable. Still waiting on my LM308h's from SmallBear, right now it's sitting with a pair of OP07s. This one's stock except for the clipping diodes, which I've swapped out for a red/ white LED pair. Considering changing out the 1uf at the ouptut for a 10uf.
The Muff has had a few things changed out for clarity, and more of a metallic, grinding fuzz texture. Chips in this one are LM1458 and OP07. Didn't have a 120n box cap on hand, so had to use a greenie.
bluescage
