DigiTech XP-100 question
Started by aran.e666, May 25, 2017, 11:42:25 PM
aran.e666
Hey guys
Ok so i'l get straight to the point and not justify why i am doing this: i am going to attemp the impossible. A complete DIY xp-100. I've done research and I'm confident it's doable. The thing I'm not so confident on is the digital side. I get that the EPROM contains the firmware/code for the effects but what i need to know is what else has firmware/is custom programmed? More importantly, does anyone have the other firmware? I have had no luck from messaging a few people who are known for modding xp-100s so i don't expect much more insight here (no offense  ;D)
Guitar is love, guitar is life.
Muadzin
Applause and respect to your DIY spirit. But why the XP-100? I have one and having tested it against the WH-1 and WH-4 I find it much the lesser of the three.
aran.e666
Totally agree that the whammy is much superior to the XP-100 however i cannot find any schatics for the whammy plus it uses even more obsolete parts. Since its also slightly different i assume it will have different firmware that nobody has. I would make one instead if anyone had a schematic but i think if i could make anything at all, it would be the xp-100 since its the pedal that has most information on it.
I don't know too much about it but maybe look deeper into the fv-1.
Rather than copy the digitech circuit, see if you can build an fv-1 circuit and get programs you need to do what the digitech does?
Maybe this will help, old stuff though. Your post piqued my curiosity and I did a quick google.
http://www.diystompboxes.com/smfforum/index.php?topic=85321.0
aran.e666
appreciate the reply, i took a look into the fv-1 and it looks quite promising for what i want to do however the reason its more ideal to try and clone the xp-100 is because i already understand the circuit (and have lots of the digital stuff from a POD). looking deeper into the fv-1 makes me think it would actually be significantly easier to make a pitch shifter but after going through the link, it seems it suffers from bad lag. i'l keep my eye on the fv-1 in case i can't make the xp-100.
also for anyone else who might see this, when i say 'XP-100' i generally mean i am making an XP-xxx circuit (they are all the same with the only difference being that different code is flashed onto the EPROM)
aran.e666
right, i just found a link to an old thread where someone asks how a whammy works and i found a massive detailed reply explaining the use of SOLA and PSOLA. i actually found a PSOLA audio shifting algorithm in C++ but i highly doubt it would work with an XP-100 as there are other programs on the XP-100. not only that but im not too sure how it would interact with the other IC's etc.
Muadzin
Quote from: aran.e666 on May 27, 2017, 11:07:19 PM
If that is what you want to do go for it! I'm sure the build report will look awesome. Me, personally? I would just buy a 2n hand WH-4. These days they're probably dirt cheap to be had.
aran.e666
To be fair, i probably should if anything make a digital pitch shifter since thats really all i am after. I would buy a second hand wh-4 but where i live im looking at minimum  £80 (about $105). Since i have most of the digital ICs i would in theory be making the pedal for cheaper.
aran.e666
after digging deeper into one of the unobtainable components, it seems that it is a 24 bit DSP with onboard ROM  :o :'(. at this point i think i better give up because there is no way to get the firmware thats flashed on that ROM. i think i will probably just make a digital pitch shifter. another option i thought about was buying an xp-100 someday then copying all of the programmed ROM so that i can duplicate the build. so pretty much like how people copied the code from the EPROM (for the XP-all mod). my only constraints with that are 1. i can't afford one right now and 2. how would i get it onto my computer? i thought about using a USB reader interface but i would have to firstly figure out the ROM's location then figure out how to actually read it via the USB adapter.
