Automatic center punch
Started by AntKnee, May 05, 2017, 10:20:34 PM
AntKnee
Mine keeps slipping and sticking. Is there a way to fix these, or do they just wear out after a while? They seem simple enough, but no matter how many times I take it apart, I can't find the problem.
kgull
I've seen the springs get bent a bit when someone used a hammer not realizing it was an automatic punch (it was a college robotics lab). If you loosened the tension a lot it still kinda worked but I usually just tore it apart and used the hardened steel tip and a hammer as a regular punch whenever I needed it.
Maybe try stretching the spring out a bit if messing with the tension doesn't do it?
Is yours the harbor freight one. I have that one and I need to take it apart every once and a while. It's left hand thread btw
My HF does it too...
I just unscrew/screw and back to punching
AntKnee
It is not the HF one. I got it on Amazon, had it for almost two years.
https://www.amazon.com/gp/aw/d/B000HTAH70/ref=cm_cr_srp_mb_bdcrb_top?ie=UTF8
Someone posted in the reviews they had the same problem, which they fixed with some graphite lube. I will try that.
stecykmi
ya mine does the same thing, ive had it for years and i cant remember where i got it anymore. it has a pretty nice machined brass (i think) handle but i do have to open it up and mess around with the spring a bit.
I have two of the General brand ones and the quality just isn't as good as it used to be.  I think I'm just going to pony up for a nice Starrett one.
I used a harbor freight one for a while, and it was infuriating. Hurt my hand to push on, would constantly misalign itself so it wouldn't "fire", just all around annoying.
Upgraded to this model from amazon: https://www.amazon.com/Neiko-02638A-Automatic-Center-Adjustable/dp/B008DXYOLC/ref=sr_1_6?s=hi&ie=UTF8&qid=1494296020&sr=1-6&keywords=center+punch
Smoother action, big plastic bulb on the end makes it a lot less palm bruising, and it even makes a better mark in aluminum. I've only used it for ~6 months or so, but its holding up pretty well too.
