Phaser pedal ticking
Started by John S, May 02, 2017, 01:44:56 AM
AntKnee
Let us know if you get it sorted.
Quote from: alanp on May 04, 2017, 01:16:00 AM
http://stompage.juansolo.co.uk/images/ps1amini-i.jpg
http://stompage.juansolo.co.uk/mod.html
Juan put one of his jacks right on TOP of the LFO in the linked build -- he wound up using an enclosed jack, and further shielding that with grounded tinfoil, and shielded wire.
Yup, it'll all be signal wires being near to the LFO. Re-wiring with shielded signal wires will almost certainly cut down the ticking. Another reason why I don't like top mounted jacks.
Also reminds me that I really need to get my finger out and build myself another PS1A at some point.
John S
Thanks for the replies. I have shielded wire on order. I plan on using the shielded wire on the in and out jacks to the switch.
Schenkenstein custom effects. Check out the page on Facebook.
John S
Ill probably add closed jacks as well. Ill report my results. Thanks again
John S
I just switched the jacks for closed ones and used shielded wire for in and out from switch to jack on each. The ticking is barely noticeable. Much improved. Ill post a pic of my build in the build report section. Thanks for all the help.
