Weird problem?
Started by giantrobot, August 23, 2011, 06:06:01 AM
giantrobot
Hey guys! I'm in need of alittle assistance. I'm wiring up a Poindexter and everything works fine outside the enclosure but once I put the jacks in the box I get nothing. I get bypass but no fuzz. I pull the jacks out and everything work fine. Anyone have any idea whats going on here? Any help would be much appreciated. Thanks
It sounds like you've got a grounding problem. Could you take a picture of what you're working with here?
mgwhit
Are you sure you're plugging into the input jack and not the output?  That's an easy mistake to make when the enclosure is open and upside down.
If that's not it, is it happening with the enclosure open or only after you screw the back on?
giantrobot
Thanks for the replies guys. I'm pretty sure its a ground problem too. As soon as the jacks touch the metal enclosure it cuts out. I just wired up a Boomstick the same way and it work fine. Heres a pic of what I got goin on.
I can see already your jacks aren't wired correctly. I'm surprised you got it to work outside the enclosure through those jacks. Your picture isn't exactly clear, but I think you've mixed up the lugs (i.e. your sleeve lug and tip lug on your output jack are wrong).
giantrobot
Yeah last night after I made the thread I switched the lugs on the output to see if the would work. Its wired correctly now but I still have the problem. I've built a couple other pedal and have never had this problem. I'm stumped :'(
giantrobot
Oh and sorry for the pic. Its my Ipod camera
Well, take a current picture, and double check your input jack. If your output jack was wired incorrectly, I would suspect that your wiring is still the problem.
mgwhit
Are you really still getting an output signal when you're in bypass mode?
giantrobot
Here what I got. Input jack- Tip=input
                                         Ring=ground
                                         Sleeve=9 volt
                       Output Jack- Tip=output
                                           Ring=ground
giantrobot
Yup I get bypass but as soon as I flip the switch nothing. I pull the jacks away from the metal and it works fine
Well first, the Battery's - lead should be on the ring, not on the sleeve, and the ground should be on the sleeve not the ring. Perhaps that's the issue?
k.rock!
#12
Quote from: jkokura on August 23, 2011, 07:40:55 PM
I think he got mixed up with the names of the connections, but the connections themselves look good to me...
I think the problem lies in your switch connection. I need to take a deeper look into it, but I think there is a combination of ground and switch connection that may be causing something funky :)
Make sure you have everything connected as it should. Use the documentation wiring of the switch.
I'm gonna try to trace your signals looking at the picture to see if they make sense...but I kinda have a feeling there's where you should be looking...
-Kaleb
God bless!
www.kalebromero.com
giantrobot
 I appreciate you takin time to help me out guys. I'm very new to the DYI world and I'm still trying to figure everything out. I'm gonna double check the switch and report back.
mgwhit
Apologies if this was mentioned earlier, but does the LED light up when it's in the case?
