Nother finishing option - Carbon Fiber Wrap
Started by madbean, March 08, 2017, 09:43:12 PM
I bought this wrap off Amazon quite a while back but this was my first time using it. To apply, I used 220 grit sandpaper and sanded cross-hatch over the enclosure. This is to create small grooves for the glue on the wrap to adhere to. I cleaned the enclosure with Acetone, then applied the wrap pretty much the same way you would do tolex. It already has a glue backing which makes it much easier. Went on really quick -t he whole cutting and wrapping took less that ten minutes.
GermanCdn
That is sexier than a Vet on Cow Husbandry day!
blearyeyes
Quote from: madbean on March 08, 2017, 09:43:12 PM
I've been looking at that stuff forever. Never popped for it. That looks really cool..
I can never figure out how to handle the corners. I'm also bad at gift wrapping.
Haberdasher
that's pretty awesome, it reminds me a little bit of the blue diamond tolex on the old ampegs.
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
bluescage
Adam_DIY
That looks ace I'm definitely having a go with some of that.
peterc
Affiliation: bizzaraudio.com
mrclean77
That looks pretty slick!  8)
Quote from: culturejam on March 08, 2017, 10:00:34 PM
I'm pretty bad at gift wrapping. I've done ok with fabric coverings, but I do avoid stuff like that CF above that would require you get the pattern straight.  :-[
TNblueshawk
Very cool.
How did you deal with the corners?
John
