Moodring Build Complete!
Started by DPTX, February 16, 2017, 03:37:33 AM
DPTX
I just finished my moodring.  If you look closely you'll see an extra black wire, that's because I installed the voltage regulator backward and when I flipped it I couldn't make a great connection for V(in).  So I tapped off the resistor connection to make it work.
It's a very sweet reverb.  I modded the tone control for a flat response.  The dwell control doesn't do too much that I notice, and I had to sub a 50k trimmer because that's all I had.  I'm very happy with the build.
Artwork is by me, as usual, with envirotex on top.  I messed up the ET coating the first time and had to start over from scratch.  This is the 9th or so ET-coated pedal, first mistake I've made with the stuff.
The art is in keeping with an underwater theme I've been doing for a while.  My phaser is the only non-aquatic themed pedal, for some reason.  My original art was different and my wife (and pedal art model) recommended I go with another underwater girl.
The top:
The guts (note extra black wire across board...grr):
And sitting on the pedalboards with the others.  All of the non-commerical pedal art is by my except for the first one I ever did, which I used an Arthur Adams picture (the green tremulus lune).
bluescage
Boba7
Wow, very very nice build, love the art!
stringsthings
Great artwork!  Excellent theme going with the pedalboard.
"Real" artists always impress me.  And I love comic books.
The guts look very tidy.  The xtra wire just makes it looks more complex in a good way.
( I'll have to subtract a point for the solder iron burn on the green wire.  ;)  I've done that too many times to count )
All You Need Is Love
DPTX
Thanks!  I was so ticked when I burned that wire.  When I do the switches I'm in "hurry and play it" mode.
blearyeyes
DPTX
I'm old school.  I draw it and ink with a sable brush.  When I do my own art I paint with watercolor after the ink cures.  For pedals I color my scanned inks in photoshop or Procreate.  Then I resize the file to match my drilling guide.  For the final art I print on t-shirt transfer and iron it onto the before before envirotex.
Lubdar
(--c^.^)--c
