Kingslayer: Can I use 430k instead of 422k resistor for R10?
Started by cpip, February 05, 2017, 07:48:49 PM
cpip
Hello,
I'm working on the kingslayer right now (2nd build ever..!) and I don't have a 422k Resistor for R10, but I do have a 430k resistor. What will this effect? does it matter if i use the 430, instead?
http://www.madbeanpedals.com/projects/Kingslayer/Kingslayer_2015.pdf
thanks!
430k will be fine...should not be a noticeable difference.
If it really irks you, check your 430s with a dmm, likely a few of them will be in the ballpark of 422, especially if you're using carbon resistors.
(But it really doesn't matter much)
