Another Zirconia
Started by juansolo, February 04, 2017, 07:34:33 PM
Lectric FX Zirconia. Much like the others. Comp pot wired backwards so it works forwards, deleted the switch, running at 18V on a charge pump (though not in the pic, because I'd forgotten it at that point, I put it in today).
playpunk
I was going to ask where you hid the charge pump you wizard. Fantastic as always.
"my legend grows" - playpunk
I have never noticed the comp pot working backwards. ??? last time you mentioned it, I actually maxed out the pot in both positions and still thought that it was correct as is. maybe I'm just not getting it.
darrenw6000
Where do you get them red switches from (high cut) and what are they called
Quote from: darrenw6000 on February 04, 2017, 08:48:29 PM
those are DIP switches and you can get them at almost every supplier
Quote from: m-Kresol on February 04, 2017, 08:37:17 PM
As standard you get more compression as you turn counter-clockwise vs the opposite if you flip around pins 1 & 3.
Maybe it's the way I build them...  :o
Quote from: playpunk on February 04, 2017, 08:30:50 PM
Oh you still can't see it, it's stuck on the underside of the board in the middle as there's a lot of stand-off between the board and the pots. :D
brucer
Gorgeous build as always John.  At first I thought you'd only placed the boards in the enclosure.  Incredibly tidy work.
Have you ever built up the Zirconia for bass?  If you have, any impressions from playing them both?
Also, what are you using for decal paper?  If I recall correctly, your enclosures are all envirotex over laser-printed decals?  They always look so amazing that I'm considering trying same.
Beautiful
bluescage
Quote from: brucer on February 05, 2017, 12:04:32 AM
Cheers!
Quote from: brucer on February 05, 2017, 12:04:32 AMHave you ever built up the Zirconia for bass?  If you have, any impressions from playing them both?
Yes, it works staggeringly well and I highly recommend it. Again I'll add the proviso that we always run it at 18v as we can have trouble with high output pickups at 9v. http://www.madbeanpedals.com/forum/index.php?topic=23724.msg232319#msg232319
Quote from: brucer on February 05, 2017, 12:04:32 AMAlso, what are you using for decal paper?  If I recall correctly, your enclosures are all envirotex over laser-printed decals?  They always look so amazing that I'm considering trying same.
They're actually adhesive transparent decal paper for ink-jet printers. But they make it for lasers too. You've just got to suck it and see on local suppliers though as some work well and some don't. I keep having to change supplier as they either stop stocking them or change the maker of it and it doesn't work well any more. When I find stuff that works, I buy enough to last me a couple of years ;) Oh and we only envirotex the tops. There's a tutorial on our site below.
czapa tranzystor 2
#11
How You have employed transistors ?
Boba7
No piece of wire in sight... wow
As always, its beautiful. Your builds are always recognizable at first sight, which is so cool.
Fit like a glove! Beautiful work, bud.
It's so perfect, then you see the V+ and G pads are flipped ...
Doesn't look like that now as it's running the charge pump... Still, my ocd shares your disappointment :)
