Arduino help
Started by studiodunn, February 02, 2017, 05:52:48 PM
studiodunn
I've had a couple Arduino boards for a little while and have decided to dive into one.
My needs are simple, but unfortunately so is my knowledge....or lack there of.
My idea is to build a box that can control all my amp switching needs.
In a two amp set up I would need to switch Channels, Boost & Reverb on each amp and then be able to A/B/Y the two amps. I also need to consider some sort of multi pin to 1/4" snake, as I cringe at the thought of all the cables running across a stage.
I've also toyed with the idea of putting looper into the mix so I can loop a part through one amp and then switch to the other for another layer of guitar. This would be cool, but for now I need to focus on an amp switching solution.
I'm really not even sure where to start with sourcing parts, but I'm guessing this is a bunch of relays being controlled by the Arduino.
Any help is much appreciated.
daleykd
Start with a non-Arduino schematic.
If you can design the schematic, then we'll plug the Arduino in to control the relays.
sturgeo
Quote from: daleykd on February 02, 2017, 07:02:05 PM
This is good advice, get the audio side of things sorted first.
To start with you'll "need" a buffered splitter, one output going to amp 1 and the other going through a isolation transformer circuit. If i was you I'd add phase inversion and ground lift switches at the cost of a DPDT & a SPDT. These switches could be relays controlled by the arduino at a later stage.
What control inputs do the amps have? 1 mono to switch channels and 1 stereo to switch boost & reverb?
studiodunn
Thanks you for the help.
That make perfect sense. I have not designed any circuits, but have done some layouts.
All the switching is via mono jacks.
