Dirtbag Delay
Started by gtr2, August 17, 2011, 11:37:58 AM
Teaser build  ;)
Prototype board complements of Brian!  This build is a beast.  Fired up on the first try and I really took my time checking every resistor and cap on this build.  Enclosure is a 125-BB with an etched aluminum plate.  It sounds awesome and the modulation can get real crazy!  Genuine mn3005's in their finest circuit.  It's a buffered bypass but it sounds great at the end of my chain.  Thanks again Brian!
Here it is!  Enjoy  :) Josh
EDIT: Rebox due to issue in lower post
& Demo http://www.madbeanpedals.com/forum/index.php?topic=2914.0
iPhone pic to be replaced in the next couple days
jimmybjj
Awesome stuff, looks good. Really excited about this one.
Pcbs no longer available
Haberdasher
Wow, great job!  I can't wait.
Are those 2 .5W or 1W resistors?
Does it use short pin pc mount pots?
thanks
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
I used these.  Steve didn't have all the values I needed in the smooth shaft so I went with the knurled.
http://www.smallbearelec.com/Detail.bok?no=1058
The two large resistors are 1W.  When sourcing I'd look for the smallest 1W resistors you can find.  Mine were a little to big but I made them work.
Josh
1/2watt is okay there, too!
k.rock!
Wow Josh!! This is beautiful!! I can't wait to hear this thing!! hehe (hint ;)) Love everything about it...the etching, the sparkly finish, the insides....perfect pedal man...
-Kaleb
God bless!
www.kalebromero.com
night-B
Very clean job! Can't wait to get the pcb... Do you plan to make a demo?
It's official. I'm going to have to make a larger effort to find a pair of MN3005 chips.
jtn191
sweet etching!
a dirtbag's definitely on my (too long) to do list  ;D
irmcdermott
Quote from: jkokura on August 17, 2011, 03:54:27 PM
me too! I want to build this thing SOOO bad.
JakeFuzz
Damn that looks good. Nice and tight in there. Do you think it is possible to fit in a 1590BB? Or should we plan on something deeper to get those jacks to fit like a 1590C or a 125BB? Is that the PPP custom aquamarine finish? Looks very good.
I'd go for the 125-BB or 1590C.  I had to file the some of the fiberboard off my jacks for clearance.  I used a 125-BB  I could have made them fit like Brians but I opted to put the pedal vertical for pedalboard space.  Either way it is REAL TIGHT and insulation was required to prevent shorts  Planning the enclosure drill was time consuming and challenging.  The revised version will have a little bit more room for clearance.  If I build another I'm sticking it in a 1790 so I can add a feedback switch and any other mods like expression jack etc...
The enclosure is aqua illusion.  It sparkles in photos but in real life it looks very dark.
Josh
cab_eleven
Without dropping the F bomb all I can say is: ____ dude, that is so ______ awesome.
The revised version (not the one shown) will make an easier time of a 1590BB. I don't think it's going to present too much of a problem.
Loztboy
This look so PRO.
I would not mind some audio samples :)
