How do make a drill template from a Diptrace board?
Started by Tuxedo3, January 27, 2017, 12:09:44 AM
Tuxedo3
Hey guys, I finished a pedal I designed (that is based around a Blues Breaker if you can tell) that I couldn't be more proud of, I am just wondering how one would make a drill template from it? Here's the board.
How I do it is that I import that into photoshop, then scale the board so the measurements match what they are in reality. Then drop them onto my regular 1590B (or whatever) template and use rulers to mark all the pots. It's actually quite simple, but you do need the measurements for the board. Also remember the board will be upside down from the diptrace when installed for labeling the pots so flip it horizontally in PS also. Doesn't really matter if it's symmetrical though.
I don't use diptrace, but your origins for your potentiometer part should be on the pot shaft center not the center pad.  This is how you correctly space everything on a layout.  So you can measure center to center on your grid or whatever measurement tool is available.  Then when you go to do a drill plot you already have your dimensions.  It's also helpful to have a document reference of the outline of the pot case shape.
Keep up the great work!  Looks good!
Josh
For three parts mounted to the pcb- quickly done using the pcb or real size printout, a ruler, pencil, paper & eraser.
Tuxedo3
Quote from: juansolo on January 27, 2017, 10:13:06 AM
Here you go.
Wow this was really helpful. Thanks so much. The board is symmetrical, I just took a snipping tool picture of the board that is why it seemed off.
Tuxedo3
Here you go.
Another question, how did you go about getting this template? Did you make it?
Actually even easier in Diptrace, though the advice above is faultless otherwise.
The pot usually includes the center mark for the shaft, enable it by right clicking the part and playing with the marking visibility options.  Make sure the board layers are all visible.  If that doesn't work, choose a different library pot in schematic via replace component, save and then update layout to schematic.  Right click is your friend.
Then, make sure the appropriate layers are visible, go to print preview, scale the view 100%, and print to printer (do not fit to margins!) and/or export as jpg. You can even set the resolution in the export settings. Easy!
