AION STRATUS (TS9)
Started by darrenw6000, January 15, 2017, 02:44:39 PM
darrenw6000
im in the middle of doing this ts9 project from Aion and the clipping is confusing me
i am just doing the stock ts9-no mods, the BOM says 4 1n914 and jumper the others
doc: https://www.dropbox.com/s/b2g113hophsg3e9/aion-stratus-ts9-documentation-v2.pdf?dl=1
however in the pdf (page 4) it only shows 2 diodes in stock
this is the silkscreen, can anyone draw on for me where the diodes go for stock version. thanks
dbp512
The top row is D3 and D2, the next row is D4 and D5, and so on. You can see the schematic 2 diodes are stacked in series in the feedback loop, so the extra pads are provided to allow for this. If you only want 1 diode instead, connect it from the leftmost pad of D3 to the circular rightmost pad on the right.
"you truly are a transistor tickler, what with the application of germanium ointment to sensitive fuzzy areas. :)" - playpunk
