aion titan not working
Started by Obie bong kanobie, January 10, 2017, 05:59:44 PM
Obie bong kanobie
ok so my voltages with no charge pump and ic in is
1-1.4 2-1.4 3-1.3 4- 0 5- .9 6- 1.3 7- 1.3 8- 2
with no ic's
socket ic1   1- 0 2- 0 3-1 4- 0 5- 2 6- 1 7- 1 8- 4.5
the 9/18v connection is on a switch   how I wired the switch was the bottom two squares go to lug 2 and top left square go to lug 1 and top right square goes to lug 3
I got these numbers with an 8v battery supplying power and I've also checked for shorts and bridges
Obie bong kanobie
https://aionelectronics.com/wp-content/uploads/2015/08/aion-titan-ocd-documentation.pdf
my current voltages are '
1-7.94 2-7.96 3-7.99 4-8.23 5-7.95 6-7.76 7-7.73 8-8.12  with no charge pump,
I was using a faulty alligator clip jumper wire my voltages are now on the high end with the same battery     I've put a new toggle switch on anyway and also tried using other ic's
Boba7
I haven't built it but why don't you just try to remove the 9/18v switch and simply jumper the two 9v pads to see if it works?
Boba7
Also, did you try it directly connected to the jacks (with no 3pdt)?
Obie bong kanobie
#4
Quote from: Boba7 on January 10, 2017, 09:38:13 PM
I haven't wired bypass wiring yet and i also haven't hooked up the input-output jacks because of how far off the voltages are     I tried it without the switch and it was the exact same thing   someone said they think its a ground issue because the voltages are so close yo the supply voltage   I cant put my finger on it tho as I'm just powering it directly thru the correct pads  :o
