Which distortion circuit to build? : high gain, tight, face melting
Started by Beedoola, August 14, 2011, 06:14:34 PM
Beedoola
I built Slow loris, and though it's an awesome circuit, I want something a little tighter. What would you suggest? I was looking into the Riot or Dr. Boogie..
J0K3RX
Quote from: Beedoola on August 14, 2011, 06:14:34 PM
I built the Dr. Boogie or "Chunk Chunk" it has tons of gain and can be very tight (great for metal) depending on the settings... Excellent all around disto box! I actually use it direct into the PC usb interface with some cab impulses and "holy mother of metal" it sounds good! You wouldn't guest that it wasn't a real boogie... I wouldn't say it has the tone of a Mark IIC+ but it does all the rest.. I am having some trouble with the Uproar but if I get it going I will probably have to go with that since that is more my kinda tone... If I can only work the bugs outa mine I will be all set! The Chunk Chunk is a harder build but for some reason it was easier to get up and running than the Uproar..? Can't go wrong with the Dr. Boogie in my opinion...
Beedoola
Quote from: jkokura on August 14, 2011, 06:47:29 PM
The BSIAB is also a candidate.
not looking for a brown sound, though now come to think of it; is the Riot
Quote from: J0K3RX on August 14, 2011, 07:14:24 PM
How is the low end on the Boogie; tight? Have you used the circuit through a loud, clean amp?
Thanks y'all!
LaceSensor
Id try a Dr Boogie or one of the variants.
I built one and it does what it says on the tin.
This is played through a Blackstar Artisan (low wattage but loud).
https://www.gigaheartsfx.com
instagram @gigahearts_fx
