The Temple of Syrinx 6 in 1
Started by bscur, December 24, 2016, 06:37:42 AM
bscur
I built this 6 in 1 effect for a friend of mine to give his son for Christmas. The kid is a huge RUSH fan, so I gave him what I thought he'd need to get a good 2112 sound
- Buffer- Unicorn Breath (Modified "Centaur" Buffer) from 1776 Effects
- Boost- SHO 'NUFF (Guitar PCB version of ZVEX Super Hardon)
- Overdrive- Guitar PCB King of the British (68 Plexi)
- Chorus- Madbean Glam
- Delay- Madbean Mimik
-Reverb- Madbean Ping
I built these stock and connected them with the Guitar PCB 3PDT wiring boards. This was my first time using the switch boards and these were really handy for the multi board.
For the graphics, I powder coated the giant enclosure white white and then drilled the holes.  Next, I put on a laser waterslide decal that I designed on Gimp featuring a painting that I thought resembled a temple. The kid is a big fan of record art like Yes and Asia, so I thought this would be interesting. Finally, I applied a clear powder coat. To avoid burning the decal, I cured it in the oven many times in shorter time increments. The back of the pedal features the lyrics to The Temples of Syrinx and the 2112 RUSH art logo. I put a personalized note on the back. The wiring in the interior isn't tidy looking- I marvel at people who make theirs look so neat.
4)
Here's an idea of how huge it is- the Blue one is my Multiplex Echo, which was the previous biggest enclosure I'd used.
I was really pleased with the detail in the waterslide because I've burned some in the past.
[URL=http://smg.photobucket.com/user/bscur/media/IMG_1558.jpg.html]
[URL=http://smg.photobucket.com/user/bscur/media/IMG_1561.jpg.html]
[/URL]
[/URL]
http://vidmg.photobucket.com/albums/v327/bscur/IMG_1545.mp4
Epic! Looks great and you really got it all in there!
Never saw that behemoth enclosure before. What is it?
inktechpatrick
Epic!
Sent from my LGMS330 using Tapatalk
bscur
Hi, it really is huge. It is a BUD Industries CN-5714 Die Cast Aluminum Enclosure, 10-51/64" Length x 6-7/8" Width x 2-5/8" Height, Natural Finish
I got it on Amazon
https://www.amazon.com/gp/product/B005T78M2W/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Wow.
I love the graphics, and the attention to details like putting lyrics on the back.  Very nice.
That would have to be almost as big as a guitar?  Bolt a neck on it and you're ready to go. :)
Man that thing is huge, what a great gift that is. Looks like you may have a winner for the BOTY too.
Great build!
I loved the cover art in those days, brings back memories.
Btw, use a laser printed water slide, and low temp clear powder (spec'd at 325f for 10 min) and you should avoid scorching.   You can also go a little lower temp wise for longer, say  300 for 15 min, with maybe a small ramp up to 325 at the end.  Keep in mind cure time is the time the enclosure is at desired temp, not just how long it's in an oven set to desired temp.
This looks great though, so my advice is probably obvious and hopefully not offensive
bscur
I really do appreciate the advice. I have had to remove several coats of powder coating on previous pedals when they burned. Not fun. The trial and error is much improved with advice like yours. Thanks. Also, have you ever had problems with white labels compared to clear? I find the white ones burn faster and are more temperamental when I apply them. If only I could print in white for black or dark pedals. This one also nearly filed the toaster oven I use in the garage for powder coating pedals, so I was nervous about proximity to the heating elements.
CK1
Holy crap, that's awesome
That looks very cool. Lucky kid. Good choice on boards too. My buddy's kid took my Mimik. We sat in my basement and did a shoot out with all my delays (boxed or not) and both of us agreed it had the perfect combination of analog warmth and nice ambience. He's a Lifeson fan as well.
Damn nice looking build.
I think the only Rush albums I've heard are Roll The Bones, and Power Windows. Both very, very pop-py.
fredwreck
Thats insanely amazing.. Great job!
Man, what a great gift.
The graphics look great on that.  And, for once, I have an opinion on whether or not it should have Velcro on the bottom (it shouldn't, obv).
Quote from: bscur on December 24, 2016, 03:29:38 PM
Oh, cool- glad it's helpful. I feel the same.
I'm not afraid to make a mistake as long as I learn something that makes it go better next time, but I try to research or ask questions first too. Stripping powder coat isn't fun for sure.
Though I found something called citrus strip which seems to not do anything at first blush, but if you spray it all over the work piece, put in ziplock bag, leave overnight, you can scrape it down without too much work. Make sure you're close to room temp while it sits. Repeat if needed. Much less toxic than other products.
I haven't tried white decals. But I can see how they might scorch easier, the pigment can change things a bit.  Distance to burners will definitely make a difference too.
If I want light markings on dark, I laser etch, and backfill with acrylic paint. I realize that might be something you don't have access to, ATM I don't either.
I have a to do list item to check out a cricut machine with foil but not sure how that will work under clear powder.
There might be some laser printers that print white too, also on my do do list to see if kinkos or staples offer that service.
