Rustbucket questions
Started by matmosphere, December 15, 2016, 03:27:08 PM
I'm really digging  the rustbucket but I'm trying to figure out how to get consistent results from it. I've only tried it on a guitar with a low output humbucker. I'm wondering how much pickups play into triggering the envelope, because right now I'm getting a very small window between no triggering and a scratchy mess.
Any advice guys.
thesmokingman
 every youtube video I see demoing the attack decay says "you have to change your playing style to use this"
Quote from: thesmokingman on December 15, 2016, 04:50:45 PM
I second that statement.
I think the problem is the EHX attack decay circuit was originally designed way too complex for what it is supposed to do. All that extra circuitry just mucks up the performance and adds noise.
The Boss slow gear is a much more simple circuit (only one IC), and does pretty much the exact same thing. In fact, I think the SG-1 is polyphonic, so it can handle chords, whereas the attack decay is limited to single notes. In other words, there's not really anything you can do to improve it's performance. It's glitchy and inconsistent by design, that's why it was discontinued pretty fast.
cajone5
In for more opinions on this.  Really wanted to build a rustbucket but if a slow gear would be better for this effect, I'm all for the simpler build.
Just in case, I just ordered some slow gear pcbs from osh park, I will have 2 extra.
after playing with it some more I want to see how throwing a comp in front of it influences the sound. It's a far more complex pedal to dial in than I thought it would be. Sounds cool though, can't wait to get some delay going after it.
Stomptown
Quote from: jimilee on December 17, 2016, 12:36:01 AM
PM'd re: slow gear PCBs!
PM'd back.
cajone5
I had a chance to try it with a compressor in front. It was much more consistent and easy to use. Bear Hug > Rustbucket > multiplex = spacey goodness.
Quote from: Matmosphere on December 23, 2016, 02:34:00 PM
Awesome, thats a great idea, I'm going to try that with my slow gear.
