Nautilus Low pass only
Started by garfo, November 03, 2016, 10:34:28 AM
garfo
Guys, I've been using the Neutron for quite some time and I'm moving the pedal to a smaller enclosure. As I want to save space and only use the Low Pass section. How do I wire it without the switch?
I was checking the project and there's S1, S2 and S3. I understand I should bypass one of these to SA. But witch one is witch?
Project: http://www.madbeanpedals.com/projects/Nautilus/Nautilus.pdf
You can find the original Nautilus project here:  http://www.madbeanpedals.com/projects/ARCHIVE/FilterMod/
On the Nautilus project, to have only the LP mode you would jumper the pads on the rotary switch that correspond to "A" and "LP". LP corresponds to the "3" lug on the rotary switch.
garfo
Thank you Brian. And if I want to have two, lets say, Low pass and Band pass, I could use a SPDT and wire lugs 2 and 3 respectively, right?
garfo
Thank you Brian. Will give it a try!!!
