Lab Series preamp questions
Started by pierre67, October 28, 2016, 09:50:05 AM
pierre67
Hi !
I got my Lab Series preamp project up and running, it sounds really good ! I still didn't calibrate the trim pots, only set the compressor trim to cero.
But before I put it in the enclosure I have a couple of questions , just to verify that the preamp is working as it should.  One is the Limit function, I get maximum compression with the knob all the way down...and the other one is regarding the Hi-Lo switch, signal is boosted in "Lo" position...it's this the way it was intended...?
Thanks for your help  :)
Droogie
pierre67
