Re: Another DeathKlaw Question
Started by K3yPr0gg3r, October 01, 2016, 06:23:38 PM
K3yPr0gg3r
So, I'm going to assume it's ok to use a 100n Cap at C22 due to no response on that question. Can I also assume that I can omit the 4k7 at R30 if I'm using a breakout on the 3PDT?
Thank you
Using a 100n for C22 will alter the character/tonality of the repeats somewhat. It makes a bit less tape-like in the way the repeats degrade. It also may change where the feedback control goes into self-oscillation.
You can omit R30 if you are using a breakout board with the LED circuitry already on it.
K3yPr0gg3r
Thanks Brian. Looking forward to building the pedal!!
