DPDT...
Started by darrenw6000, September 15, 2016, 03:23:02 PM
darrenw6000
Is there a difference between the DPDT ON-ON-ON and the ON-OFF-ON or are they the same
There is a difference for sure.
a On-Off-On will connect the centre lugs with either side in the On position, but will connect to neither when Off.
A On-On-On switch is often a A-Z-B switch meaning that in A and B it will connect the centre lugs to side A or B. In Z (centre position) it connects one middle lug to side A and the other middle lug to side B.
I'm not sure but I think there are different versions.
the pic below is actually missing pins in the ON-ON-ON graphic. should be 6 pins to and the centre pins are usually not connected, iirc.
darrenw6000
Drew Hallenbeck
Building with my daughter and occasionally selling as "Daddy Daughter Pedal Works"
Not for any real profit, just trying to have a self-funding hobby.
