Sub-Mini 3PDT?
Started by daleykd, August 05, 2016, 03:07:20 PM
daleykd
I know that we can obtain sub-mini SPDT and sub-mini DPDT (they're used in at least the 1590G builds here), but is there a sub-mini 3PDT anywhere?
Quote from: daleykd on August 05, 2016, 03:07:20 PM
I haven't seen a "Sub" mini 3PDT switch. Lawrence at BLMS has theses.
They are a little smaller than the regular 3PDT switches. They DON'T fit in the wiring boards so you will have to direct wire right to the switch. Here is a link
http://bitcheslovemyswitches.com/#!/Low-Profile-3PDT-Footswitch-Latched-Solder-Lugs/p/33283018/category=5027572
daleykd
My mistake.  I should have been more specific.  I meant toggles.
Sent from my SM-G920V using Tapatalk
http://www.skycraftsurplus.com/subminiaturetoggleswitch3pdton-on6a.aspx  Like this? I've never had use for a 3PDT toggle so I'm not sure what the size comparison should be.
daleykd
Quote from: somnif on August 05, 2016, 08:27:23 PM
This is pretty close to what I was thinking.  I'd have to see one in real life to have a better idea.
It would be nice if they provided a data sheet so you could see dimensions and pin spacing.
neandrewthal
Quote from: daleykd on August 07, 2016, 07:01:25 PM
Something seems off. I don`t claim to be an expert, but usually when I look at a picture of an actual sub-mini switch even without a scale something about the proportions screams to me ``Im a sub-mini switch``. This one doesnt. Also, 6mm mounting hole.
neandrewthal
Wait, click view more images and go to page 2. It hasll the dimensions. Definitely not sub-mini.
daleykd
Quote from: neandrewthal on August 07, 2016, 07:53:26 PM
It didn't set right with me either; thanks for doing the leg work.
I can live with a DPDT; it just means no LED. :(
http://www.alliedelec.com/nkk-switches-m2032bb1w01/70192115/ appears smaller, though again without a frame of refference its hard to tell for certain.
Quote from: somnif on August 07, 2016, 09:47:35 PM
.492" mounting hole size makes that a huge lever with a small body.
daleykd
FWIW, I gave up on this.  I just decided to use sub-mini DPDTs.
Maybe someday we'll find something...
