1st Build! Some Questions...
Started by Mantaray14, July 21, 2016, 03:10:50 PM
Addy Bart
Looks great indeed!
If that LED bothers you, try one of these:
http://www.musikding.de/Washer-M12-2mm
They are slimmer than those white nylon washers so the LED won't look so close to the footswitch.
BrianS
That's really impressive. I finally bit the bullet and bought one also.  I hope mine will work but wow there's a lot of parts that I can screw up. Great job!
Mantaray14
I just ordered the parts from the pre-selected cart in the build doc. 90% of the parts are there and clearly labeled by mouser.  From there just take your time and go one part at a time!
Hearing yours made me realize that there is clearly something wrong with my build. I tried to bias it twice and it is quite distorted. Need to open it back up and check for errors.
great job and nice audio demo
Martan
Excellent job! You learn so much the first build, but then of course you want to build something else:)
For biasing, it sounds very good! A little grit but lovely. I think I rebiased mine 3 or 4 times. It should sound close to the sweetest delay you've ever heard when its right. It really is a GREAT pedal.
Mantaray14
#35
The grit in the recording is from the phone.  I was very surprised it sounded that good using just a cell phone!
FWIW,  I'm already building an Afterlife...
